406 estate 7th seats
Hi all,
estate rear 7th seat question.
how do you go about these if removed?
do you notify dvla or do insurers just go ahead and insure as 5 seat
im planning on buying a 7 seater later,but iwill be binning the back seat's as iwill be just using it as 5 seater.
Reason? im paranoid about using back seats/my kids wouid be banned from using them so iwant seat gone.not trying to start debate btw.
Re: 406 estate 7th seats
Ive' just spoken with insure'r theyre fine with it.
so its just a case of remove.and notify dvla..
once log books change they amend to 5 seat's and change price.
Hi Lozz, I would simply put a load cover in the back and leave the seats where they are - just forget they are there, or..
1) To remove them you will need a donor car for the replacement wooden boot floor / spare cover, replacement metal rings to hold floor down and a couple of other bits and bobs. If you do the swap all you gain is about an inch of height in the boot, as the 7 seats have a slightly raised frame and padded carpet surround.
2) I guess you could keep the seat frame but strip the seats so you have a sort of hidden compartment under the floor... :supafrisk:
3) Sell the conversion for £75 minimum and get replacement bits from a scrapper.
DVLA are cool with the change and tax class is unaffected.
