Servicebox info (paint code)
Posted: Wed Sep 25, 2013 9:10 pm
by munkymanmatt
Can someone give me the servicebox details for my car?
I need my paint code at the moment but have a few other things I'll need soon.
my VIn is VF38BDHXE80148095
Thanks in advance
Re: Servicebox info (paint code)
Posted: Wed Sep 25, 2013 9:22 pm
by jonsowman
Vehicle characteristics
Vehicle family 406
Build code 07106 89 3 0210
Warranty Start Date 01/01/1990
General information
PRODUCT TYPE CAR
COMMERCIAL MARQUE/COMPONENT TYPE PEUGEOT
VEHICLE FAMILY 406
SILHOUETTE 4 DOOR SALOON
TRIM LEVEL LEVEL 3
ENGINE TURBO DIESEL XUD9TE
TRANSMISSION BVM5
PAINT TYPE METALLIC PAINTWORK
BODY COLOUR EGE - CHINA BLUE PAINT
INTERIOR TRIM TYPE DUNE VELVET "BM"
UPHOLSTERY COLOUR "FT"
GEARBOX (CHARACTERISTICS) BE3 L
ENGINE (TYPE) XU/XUD
BADGE GLX
TRIM LEVEL LEVEL 3
STEERING UNVARIABLE POWER STEERING
SPEEDOMETER DRIVE TACHO TORQUE 22X18
Fuel supply-Engine
FUEL DIESEL FUEL
EMISSIONS STANDARD (ENGINE) EEC 95 DEPOLL (ENGINE)
PRE-FILTER ASSEMBLY WITHOUT PRE-FILTER
SPEED SENSOR SIGNAL SENSOR HALL EFFECT
CATALYTIC CONVERTER 3 PARTS CATALYST
OIL COOLER MNTG WATER/OIL EXCHANGER ON ENGINE
FUEL TANK INSULATION WITHOUT FUEL TANK INSULATION
CRANKCASE GAS CIRCUIT HEATING W/O HEATER CASING GAS CIRCUIT
RHEOSTAT RHEOSTAT
FAN 2 FANS , 2 RATES , UPPER
FUEL VAPOUR RETRIEVAL WITHOUT PETROL VAPOUR RECUPERATION
INJECTION ASSOCIATED VARIANT W/O INJECTION VARIANT
Gearbox Transmission
TRANSMISSION BVM5
FINAL DRIVE RATIO REAR AXLE HYPOID GEARSET 14 X 62
WHEEL STYLE ALLOY WHEEL OPALE
CLUTCH CABLE CLUTCH
GEARBOX SAFETY LOCK W/O G/BOX SECURITY LOCKING
TYRE (SIZE, TYPE) 195X65X15 H TYRES
WHEELS FITTED 6" RIM ROAD WHEELS
WHEEL (TYPE) ALLOY WHEELS
Suspension-Steering-Brakes
ABS WITH ABS BRAKES
REAR ANTI-ROLL BAR REAR ANTI-ROLL BAR DIAM 22
ANTI-THEFT DEVICE STANDARD ANTI-THEFT
FRONT ANTI-ROLL BAR FRONT ANTI ROLL BAR DIAM 24
TRACTION CONTROL WITHOUT ANTISLIPPING
SERVICE BRAKE WITH COMPENSATOR SLAVE
BRAKE TYPE VENTILATED FRONT DISCS/REAR DRUMS
POWER STEERING FLUID COOLING SYSTEM WITH COOLING
ACTIVE SUSPENSION WITHOUT VARIABLE SUSPENSION
Body fittings
HORNS HORNS-HARMONY
AERIAL LONG ROOF AERIAL
WIPER ARM FRONT BLADE WITH DEFLECTOR
SIDE MOULDINGS (TYPE) PROTECTOR W/O CHROME RING
WHEEL EMBELLISHER (STYLE) SMALL DIAMETER HUB CAP
SIDE REPEATER INDICATORS SIDE FLASH-UNIT ASSEMBLY
INDICATORS WITHOUT SIGNALING LIGHTS
THIRD BRAKE LAMP WITH EYE LEVEL REAR LIGHTS
SILL ILLUMINATION LAMP WITHOUT SILL ILLUMINATION
ADDITIONAL SHIELD (UNDER ENGINE) W/O ENGINE UNDERSHELDING
WASHER JET WINDSHIELD WASHER JET W/O DEFROST
EXT. REARVIEW MIRROR COMP. FUNCTION WITHOUT FULLER FUNCTION
EXHAUST TAILPIPE TRIM W/O EMBELLISHER
ENGINE BAY SOUNDPROOFING BONNET SOUND-PROOFING
WINDSCREEN GLASS (TYPE) NO HEATING WINDSCREEN
WINDSCREEN WIPER INTERMITT AUTO FR WIPER BLADE
REAR SCREEN WIPER W/O REAR SCREEN WASH WIPE
HEADLAMP WIPER W/O HEADLAMP WIPER
FRONT PANEL BLANK WITHOUT FRONT BUMPER PLUG
BUMPER BUMPERS WITHOUT EMBELLISHER
MUDFLAP WITHOUT MUDGUARD
LUGGAGE RACK WITHOUT ROOF BARS
FRONT FOGLAMP FRONT FOG LIGHTS
EXTERIOR REAR VIEW MIRROR (DRIVER SIDE) HT EXT RRVW MIRROR EL INT CONTR
EXTERIOR REAR VIEW MIRROR (PASSENGER SIDE) OUTSIDE PASS RRVIEW MIRROR HEATED ELEC CNTRL
SPARE WHEEL ALLOY WHEEL + STANDARD TYRE
EXTERIOR ACCESSORIES DOOR MIRROR AND HANDLES BODY COLOUR
SUN ROOF ELECTRIC SUN ROOF
GLASS (APPEARANCE) TINTED
REAR QUARTER WINDOW (TYPE) WITHOUT REAR QUARTER GLASS
WINDOW (TYPE) LAMINATED QUALITY 2
Interior fittings
REAR HEAD RESTRAINT REAR HEADREST ADJUSTABLE
FRONT HEAD RESTRAINT JOINTED FRONT HEADREST
REAR SEAT REAR BENCH SEAT SINGLE CUSHION SEPARATE SEAT BACKS
SUPPLEMENTARY SEAT WITHOUT SUPPLEMENTARY SEAT POSITN
REAR SEAT ARMREST WITH REAR ARMREST
INTERIOR ALARM ALARM FORGET LIGHTS
RADIO TELEPHONE WITHOUT TELEPHONE PRE-EQUIPMENT
LUGGAGE COVER WITHOUT LUGGAGE COVER
FRONT SEATBELT PYROTECHNIC SEAT BELT WITHOUT ALARM
AIR CONDITIONING MANUAL CONTROL CAR HEATER
SPEED GRADUATIONS GRADUATION MPH
TACHOMETER REV COUNTER WITH NEEDLE
RADIO EQUIPMENT FEED AERIAL RECEIV FRT SPEAKER TWT REAR SPEAKER
CONSOLE LONG CONSOLE
DRIVING POSITION RIGHT HAND DRIVE
REMOTE CONTROL REMOTE CONTROL ASSEMBLY
LOAD SPACE LIGHTING GLOVE-BOX LIGHTING
DASHBOARD EQUIPMENT DASHBOARD LARGE GLOVE BOX COVER, WOODEN TRIM
INTERFERENCE SUPPRESSION RADIO INTERFERENCE SUPPRESSOR
MISC. INT. LAMPS MAP READING LAMP
LOAD SPACE TRIM TRIM BOOT + RR TAILGAT FLAP
DOOR TRIM WOOD TYPE DECORATION
TACHOMETER (SIGNAL CONNECTION) REV COUNTER CALC
CHILD SEAT ANCHORING POINTS WITHOUT CHILD SEAT MOUNTING
LOUDSPEAKER MOUNTING 4 LOUDSPEAKERS + 2 TWEETERS
RADIO CONTROLS REMOTE RADIO CONTROL
POLLEN FILTER WITH POLLEN FILTER
SCREENING (BLIND, SIDE SUNBLIND, SUNROOF) WITHOUT SUN VISOR SCREEN
DRIVER SEAT CONTROL DRIVERS FRT SEAT MANUAL CNTROL
FRONT PASSENGER SEAT CONTROL PASSENGER FRT SEAT MANUAL CNTR
DRIVER SEAT ADJUSTMENT DRIVER’S LUMBAR ADJUSTMENT
FRONT PASSENGER SEAT ADJUSTMENT PASSENGER TILTING BACK
INT. UPHOLSTERY ELEMENTS NOT WEAVED ROOF TRIM
FRONT SEAT ARMREST ASSEMBLY WITHOUT FRONT ELBOW REST
EXTERIOR TEMP. INDICATOR EXT TEMP INDICATOR
COMPACT DISC WITHOUT COMPACT DISC
HANDBRAKE WARNING LAMP WITHOUT PARKING BREAK INDICATOR
REAR WINDOW LIFT ELECT CONTR RR WINDOW LIFTER + LOCK SYSTEM
DRIVER’S WINDOW LIFT SEQUENTIAL DRIVER’S ELECTRIC WINDOW
PASSENGER’S WINDOW LIFT ELEC CNTRL PASS FRONT WINDOW LIFTER
DISPLAY DISPLAY (RADIO+CLOCK AND OR TEMP, CD)
CLOCK NUMERIC CLOCK
COURTESY MIRROR DRIVER+PASSENGER WITHOUT LIGHTING
OIL GAUGE STD OIL LEVEL INDICATOR
FITTING REAR HEAD RESTRAINT MOUNT 2 REAR HEAD-REST
HEATING ELEMENT NON HEATED SEAT
FRONT LATERAL AIRBAG WITHOUT FRONT SIDE AIRBAG
PASSENGER AIRBAG PASSENGER AIRBAG
ELECTRIC WINDOW (OPERATION) DRIVER + PASSENGER ELECTRIC WINDOW AUTO STOP
LOUDSPEAKER GRILLE (REAR PASSENGER COMPARTMENT) WITH REAR SHELF LOUDSPEAKER GRILLE
ON-BOARD COMPUTER NO COMPUTER
COURTESY LAMP FR+RE DOORS CONT - FR+RE INTERIOR LAMP
HEADLAMP HEIGHT ADJUSTER REMOTE MANUAL HEADLAMP ADJUSTMENT
FRONT SUN VISOR DRIV+PASS SIDE (W/O NOTICE)
STORAGE (DRIVING POSITION) OPEN CONSOLE SETTING+UNDER FR SEAT
RADIO RECEIVER PERFORMANCE 5 RDS RADIO
REFRIGERATION WITHOUT AIR CONDITIONING
CRUISE CONTROL WITHOUT SPEED CONTROL
DRIVER’S SEAT HEIGHT CONTROL PARR+FR DRV HEIGHT ADJ
INTERIOR REAR VIEW MIRROR DAY -NIGHT INNER REAR MIRROR
RHEOSTAT RHEOSTAT
AIR CON./TEMPERATURE REGULATION WITHOUT REGULATION AIRCON/TEMP
STORAGE (OTHERS) FRONT SEAT STORAGE + 2 BOXES IN BOOT
CARPET COVER W/O CARPETMAT
DRIVER AIRBAG DRIVERS AIR BAG
CARPET DILOURS CARPET F330
LIGHTING TIMER ADJUSTABLE TIMER
SWITCH CODED IGNITION
COOLANT LEVEL WARNING LAMP WATER LEVEL WARNING
ANTIPOLLUTION MALFUNCTION WARNING LAMP WITHOUT ANTIPOLLUTION MALFUNCTION LED
LOCKING CONTROL CENTRAL DEAD LOCKING
STEERING WHEEL RUBBER STEERING WHEEL,4 BRANCH
Electrical
ALTERNATOR ALTERNATOR 80 AMP
HORNS HORNS-HARMONY
BATTERY BATTERY L2 300
STARTER MOTOR STARTER MOTOR CL 5
SPECIAL LIGHTING WITHOUT PARTICULAR LIGHT
Component manufacturers
Miscellaneous
SPECIAL SPECIFICATION STANDARD
ATMOSPHERIC CONDITIONS NORMAL ATMOSPHERE
FIRST AID KIT WITH FIRST AID BOX
TRAFFIC SIDE DRIVING ON THE LEFT-HAND SIDE
SIDE IMPACTS DOOR WITHOUT REINFORCEMENT
SET OF KEYS 2 H/F PLIP KEYS+1 SECONDARY
SURFACE CONDITIONS GOOD TERRAIN
SPEED MONITORING WITHOUT SPEED CHECK
EMERGENCY WARNING TRIANGLE WITHOUT WARNING TRIANGLE
Posted: Wed Sep 25, 2013 9:25 pm
Beat me to it
Jeebus, what a list. Nobody quote that or there'll be twubble.
Posted: Thu Sep 26, 2013 1:13 am
by munkymanmatt
Awesome thanks very much both of you
