wind deflectors,
wind deflectors,
as anyone on here fitted wind deflectors?
whats with the metal clips?
ive put them on but the instructions might as well be in Brail,
which way round shouid the metal clip go, the side with the prong on does that go against the plastic or the seal?
tried putting them on with no clips but they go loose, so ithink them clips are needed,
they might as well make them clips out of razor blades cut my fingers to bits with them,
omega
Re: wind deflectors,
Post by omega »
theres a vid on you tube about fitting them
in it they say you dont always need them clips
mine dosnt use them
omega wrote:theres a vid on you tube about fitting them
mine dosnt use them
Cheer mate,
it deffo needs the clips or they will fall off,
ive just ramd the clips in for now, hopefully they wont fall off,
you dont need the clips for the front because its impossible for them ones to fall out.
ive got wind deflectors on my d8 and i havnt used the clips on all 4 doors. the front sit in perfect and will never fall out
the rear i used cyonacrilate super glue and bonded them to the rubber .
itried them withought the clips they just make the electric window go crazy,
ive sorted them now, thanks to omega, igot the idea of the you tube How toos,
the clips are easy to put in, ihad put them in wrong, :oops:
The side with the tooth i face into the rubber then it gets more grip, although when i ordered the deflectors (heko ones) i got them to send extra clips, what also helps is to get a big flathead screwdriver and ram it into the window run channel as opposed to using the power of the electric window to put them into place.
FarmerPug wrote:The side with the tooth i face into the rubber then it gets more grip, although when i ordered the deflectors (heko ones) i got them to send extra clips, what also helps is to get a big flathead screwdriver and ram it into the window run channel as opposed to using the power of the electric window to put them into place.
Thats what itried doing,
but these renaults must have sensors, the window just cut out and wouidnt work again until ign-on and off twice,
ive got the Clips sat right now so, theyre secure,
idont think that tape whats on them wouid of held them in place for long, idont know how thin the winddeflectors are for the 406s but these ones are wafer thin,
but theyre coshir, thought they where fake ones at first,
Ah the window run channels on the 406 are much more forgiving than the ones on the nissan primera, they can compress a lot more. On my dads nissan it had wind deflectors and it jammed at the top then cut out and it wouldn't work for about 30 mins, even after removing the wind deflectors the primera still did this, only after changing the run channel and applying silicone grease on the runners did the problem go away.
I think nissan and renault are using the same electric windows
Irish406
Post by Irish406 »
Eoin
2000 406 1.8 Petrol D9 (Selection Pack)- Ireland
To do - Get manual/service book, wind deflectors, Get the buttons on the remote central locking sorted, replace tape unit
