My bro has this problem on his D8 estate - the rear seat / belts are never used, but he noticied it the other day and the MOT's due in a week or so.......
Anybody had, or sorted something similar?
Or know how to get at it?
Any suggestions gratefully received, (I have a feeling muggins will get roped in eventually).
Estate centre inertial reel seat belt jammed
- waue1978
- HDi don't believe it!
Re: Estate centre inertial reel seat belt jammed
I did this with Wiggy's old back seat mate. Not as bad a job as I first thought to get at, but not too sure about fixing the mechanism:
viewtopic.php?f=10&t=14926&hilit=+rear+seat
- Bailes1992
Just unbolt the belt from the chassis under the rear bench and let ir retract.
Worked a treat on my D8!
Thanks for the info & suggestions guys, now we have some idea where to look.
Maybe I should have said, it's fully retracted and doesn't want to come out to play.
Two things of note - one is that you should let it retract with the car on the flat and the seat locked upright. Second is that if the bolt's seized, there's a risk that the captive nut underneath the car could come free while trying this - as happened with my tubby estate.Bailes1992 wrote:Just unbolt the belt from the chassis under the rear bench and let ir retract.
Thanks for the tip Matt, I'll pass it along.
