heater matrix,
i had to bend off a couple of screws which are in impossible places so they cant be put back on, did anyone manage to get there gloveback back to normal after?
glovebox wont close properly since removing it all to change
Re: glovebox wont close properly since removing it all to ch
When I had my glove box out I put it back without the awkward screws had a problem with the latches I took both off fitted one making sure it latched then the other problem solved it did take some patience but sorted it
- highlander
- PowerFlow Shill
The lock on mine rattles and vibrates as I'm driving along and OH MY GOD does it drive me NUTS. I know it's the lock because if I press my finger against it, it stops.
Temporary solution is to crank up the stereo
but how do I fix that one long-term?
Smartie tubehighlander wrote:The lock on mine rattles and vibrates as I'm driving along and OH MY GOD does it drive me NUTS. I know it's the lock because if I press my finger against it, it stops.
Temporary solution is to crank up the stereobut how do I fix that one long-term?
- highlander
- PowerFlow Shill
I should add that I don't want to appear on http://thereifixedit.failblog.org/ either
