Yes - if the seats aren't memory seats then they only need a live & earth feed to the yellow plug. The only reason an earth needs soldering to the drivers seat switch on a memory seat is because the power is routed through the ECU.Roylewaa wrote:Ok, Im down to 2 options really as car electrics aint really a strong point, Could I find a electric drivers seat out of a GLX and swap the base over, and retrim the leather base so the seat wouldint have an ece and just need a live and neg feed, would an earth still needed to be soldered onto the switch?
But surely if you are brave enough to strip the leather & retrim a GLX seat base it would make more sense to strip the leather seats & transplant onto your manual bases?
