Page 1 of 2
updating coupe front badge
Posted: Mon Dec 06, 2010 6:29 pm
by swampyv6
as you know i have being looking to update the badge, well today the carbon fibre arrived
standered badge as it comes from the car
three parts of standered badge,
very easy to get to this point, just cut the heads off the plastic rivets and it comes aprt
template was made and the carbon fibre was cut!!
pretty impressed with how it looks, just need to get some small drills so i ca make the holes for the lion to pop through.
will then stick it all back togeather and take more pictures of it on the car
the above image is actualy the reverse of the plate i made, once its in place and on the car i think it will look ok.
PROGRESS ON THE REAR BADGE IS ONE WILL BE GOING TO THE COMPNAY IN THE NEXT FEW DAYS TO BE SCANNED AND IMAGES MADE!
THEN I WILL BE GETTING PROTO TYPES TO LOOK AT PRIOR TO PRODUCTION!!
Re: updating coupe front badge
Posted: Mon Dec 06, 2010 7:35 pm
by Gary406
you got a close up pic of the front one complete ?
Posted: Tue Dec 07, 2010 10:00 am
by swampyv6
Gary406 wrote:you got a close up pic of the front one complete ?
not yet as the lion isnt mounted as i havent got any drills small enough
they are on the shopping list for today so should all be done by the end of the week
Posted: Tue Dec 07, 2010 11:41 am
by FarmerPug
off topic i know but does your coupe have a cd player and jbl amp?
Back onto the topic good stuff with the carbon fibre it looks good
Posted: Tue Dec 07, 2010 1:38 pm
by mjb
How do you get the badge off the car and split it up? Could do with giving mine a good clean and a splash of paint :)
Posted: Wed Dec 08, 2010 2:09 pm
by swampyv6
mjb wrote:How do you get the badge off the car and split it up? Could do with giving mine a good clean and a splash of paint :)
on the coupe there are two m6 nuts under the bonnet, un do them and then cut the sealant away on the outside between the badge and the bonnet.
on the rear of the badge the parts are held togeather with plastic welds, cut these off and then it comes apart.
to reassemble you will need to clue the pins on the back and use double sided trim tape to stick back down to the bonnet
Posted: Wed Dec 08, 2010 2:10 pm
by swampyv6
406executiveHDI wrote:off topic i know but does your coupe have a cd player and jbl amp?
it has a jbl amp and changer in the back not sure of they work as im running an aftermarket head unit
Posted: Wed Dec 08, 2010 3:16 pm
by Captain Jack
What is it with you and JBL amp/CD player questions? :P :supafrisk:
Posted: Thu Dec 09, 2010 12:29 am
by FarmerPug
I seized the opportunity to ask this question.
Posted: Fri Dec 10, 2010 2:49 pm
by swampyv6
the finished article!!!
doesnt look too bad i dont think
Posted: Fri Dec 10, 2010 3:10 pm
Mmm, that there carbon fibre - is it just a fake lamination of the carbon effect? if so do you think that water will get in-between the laminate and bubble up? I only say this as it's the lamination fault that affects the rear badges on the saloons :(
Posted: Fri Dec 10, 2010 3:34 pm
by swampyv6
nope that there is proper carbon fibre!!!
it wont be bubbling!!!
and it aint cheap.
if i was to make any to sell i would need to charge £20 each for just the carbon part, or £30 for me to dismantle yours cut and shape the carbon and re bond in place
Posted: Fri Dec 10, 2010 6:00 pm
by FarmerPug
Carbon fibre is also lighter so your car will go quicker now to that wheight saving part swap.
Posted: Sat Dec 11, 2010 10:56 am
by swampyv6
hahaha
so are the stainless steel nuts ill be fitting it back on with!!
cant see me getting under a 10 second qtr with that mod though
Posted: Sat Dec 11, 2010 6:35 pm
by FarmerPug
Then you jump into the car with 2p in your pocket which will offset all the hard work with the carbon fibre. Im getting a feeling its about the aestetic improvement rather than shaving weight.
