Need a Definitive How-To for removing instrument cluster
Posted: Mon Jun 14, 2010 7:26 pm
by highlander
Hi all,
I tried removing the instrument cluster this evening and
my god the damn thing just didn't want to come out
I removed the three screws from the top, and managed to move the left side (with the two vents) out, but the right side (with the one vent) wouldn't bloody shift.
So I opened the drivers' door, and prized off the little panel there. There I see two screws, which I undo, but the damn thing still wouldn't move.
Is there a pictorial step-by-step anywhere that shows how to take the black bit out? I'm pretty sure I can see how to remove the instrument cluster itself once I get the black surround out, but my car is being unco-operative (and the bitch bit me again, nasty little pinch on my index finger, making it sore to type
Graeme
Re: Need a Definitive How-To for removing instrument cluster
Posted: Mon Jun 14, 2010 7:58 pm
by HimBigChief
The right side just pops out aswell. I use a fair size screwdriver wedged down the side and pop it out that way. You may brake the little clips on the vent part, but it will go back together fine. You then squeeze the top down a bit and pop it out. Make sure the steering wheel is on it's lowest level too. Pretty sure the 2 screws you've removed are for the lower dash panels so I'd stick them back if I were you.
Posted: Tue Jun 15, 2010 10:45 am
by mjb
If you've got the side panel off, you should just be able to push the vent section out the front...
Posted: Tue Jun 15, 2010 11:21 am
by Archangel
Cluster is 4 torx heads ,2 top 2 bottom
yes it is a bitch to remove, especially just to change the bulbs (2 quid each from dealer)
Posted: Tue Jun 15, 2010 4:06 pm
by plod
When I did mine it was 3 torx across the top, then open drivers door
prise off access panel, and remove forth torx screw.
Lower the steering wheel and pull forth at same time to give maximum room.
Then pull the surround out - the top will need pulling down as the parts where the 3 screws went in the top, stick up into the dash a little way.
Posted: Tue Jun 15, 2010 6:08 pm
by highlander
Got it guys, thanks
It's a bugger to open.
I was fitting the chrome dial rings. Got them in, but the fuel gauge sticks. Will need to take it all apart
again to try and sort it
but at least now I see how it's done
Posted: Tue Jun 15, 2010 6:15 pm
by plod
Someone else had problems with them sticking, but I had no problems at all.
I made sure the bottom flat bit was seated correctly first before trying to bend the ring around.
Posted: Thu Jun 17, 2010 7:59 pm
by swiss
If you take the cluster out, put it back in but do not secure it. Don't screw it in or put the vent cowling back. Just plug it in and drive around for a few days to check it out. Because my God, you pull it, do stuff, put it back and realise it has to come out again and you really, really feel the urge to kill somebody.
Posted: Thu Jun 17, 2010 10:50 pm
by highlander
plod wrote:Someone else had problems with them sticking, but I had no problems at all.
My dials are fully round, there is no flat bit on the bottom.
Was that a D8 thing?
Posted: Fri Jun 18, 2010 8:23 am
by plod
I guess so
Posted: Mon Jun 21, 2010 12:15 am
by Archangel
swiss wrote:If you take the cluster out, put it back in but do not secure it. Don't screw it in or put the vent cowling back. Just plug it in and drive around for a few days to check it out. Because my God, you pull it, do stuff, put it back and realise it has to come out again and you really, really feel the urge to kill somebody.
Oh yeah , I agree with that.
BTW, there are at least 30 bulbs for illumination and completely replacing them is good idea
Posted: Mon Jun 21, 2010 9:03 pm
by swiss
Pop in some LEDs while you're there, never change them again ^_^
