Volume knob flaky
Posted: Wed Jun 02, 2010 8:58 pm
by FarmerPug
The volume knob in my D9 (i think im correct its an 2002 model) is flaking its as if some paint from it has come off, i have seen this problem before in a toyota avensis, but i did not own that car and therefore paid no attention to the issue, but in the 406 i have noticed the volume knob flaking, as is the grab handles on the back doors, i assume its some sort of special paint what is it called, or what can be done to repair it.
Re: Volume knob flaky
Posted: Wed Jun 02, 2010 9:17 pm
by FarmerPug
I would attach a picture but i cant seem to figure out how its done, when i go to the attachment option it says 'sorry the board attachment quota has been reached'
Posted: Wed Jun 02, 2010 9:20 pm
by Gary406
you need to open a PHOTOBUCKET account its very easy and free
upload the pictures to your photobucket account 1st, then when in photo bucket you can get the IMG link, just copy the link from photobucket and paste it into your reply on this forum ,
you will know what i mean with the IMG link when you see a pic in photobucket, you get 4 links, only use the IMG one
Posted: Wed Jun 02, 2010 9:26 pm
by plod
Posted: Wed Jun 02, 2010 9:38 pm
by FarmerPug
ok heres the images of the problem
the bad volume knob:
and then the grab handles in the back are going the same way:
what would the problem be here
Posted: Thu Jun 03, 2010 7:44 am
To me this kind of wear would indicate high usage of the vehicle. Was it used as a taxi or other commercial use?
I think the only remedy would be new donor parts from new door cards and a new stereo
Posted: Thu Jun 03, 2010 8:50 am
by Blue406
Ah, I see that all the time in the scrapyard. Tis the rubberised coating coming off.
The volume nob is piss easy to replace they just pull off and push on. Need a little encouragement mind you.
The door handles are the difficult bit. They are plastic welded to the door cars. If you are handy with tools it is possible to remove them from the door cards and attach replacements with bolts, washers and a couple of load plates on the inside of the door card to spread the load a little and allow for a tight fit.
Posted: Thu Jun 03, 2010 9:20 am
by highlander
Blue406 wrote:The door handles are the difficult bit. They are plastic welded to the door cars. If you are handy with tools it is possible to remove them from the door cards and attach replacements with bolts, washers and a couple of load plates on the inside of the door card to spread the load a little and allow for a tight fit.
I need to do this to mine; the leather exec door cars I bought appear quite shabby - well, the rear ones do anyway.
I am no good with tools though, other than a screwdriver. It's a bit irritating that the grab handles are plastic welded on, and not fixed in with torx screws
like every other fixing on the door is.
Plus, I no longer have the original LX-spec cloth door cards, so I don't have the grab handles that don't have electric window switch holes cut in them any more
Posted: Thu Jun 03, 2010 9:31 am
by Blue406
We need to arrange a 406 fixing day. You can pop down to my place for a cuppa and some TLC on your 6
I can get the handles and I'm fairly ok with tools.
Posted: Thu Jun 03, 2010 9:47 am
by FarmerPug
And theres only 92000 miles on my clock, its service history shows it was an ex peugeot fleet car so it must have been used a lot, but ill keep an eye out for these parts, i am handy enough with tools that doesnt sound like a big issue
Posted: Sun Jul 11, 2010 4:27 pm
by FarmerPug
After looking on the internet i noticed a product called plastidip, its on ebay at
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 452wt_1137 would it be the solution to this problem has anyone ever used it.
Posted: Tue Jul 13, 2010 2:54 pm
by sirwiggum
I peeled the remaining covering off my volume button, so now it looks matt. Doesn't look too bad!
Posted: Tue Jul 13, 2010 4:56 pm
by Captain Jack
sirwiggum wrote:I peeled the remaining covering off my volume button, so now it looks matt. Doesn't look too bad!
Ditto!
Posted: Tue Jul 13, 2010 8:06 pm
by FarmerPug
When it peels off mine it looks a bit like pound stretcher glossy cheap plastic not matte, would that plastidip do the job, at getting it back to original?
