Seat Airbags
Posted: Tue May 11, 2010 10:42 am
by waue1978
If you had a car fitted with the airbags in the seats & replaced them with a set that didn't have the serat airbags, would this cause the airbag warning light to flash up on the dash?
Re: Seat Airbags
Posted: Tue May 11, 2010 1:00 pm
Yes.
Re: Seat Airbags
Posted: Tue May 11, 2010 1:19 pm
by waue1978
Good job I checked then. Damn - 406s are so limited when it comes to upgrading things. Best make sure I get seats from a post 2000 model then. Pity though, because there's a really nice set on Ebay from when they didn't have the horizontal seams & they look a lot comfier than the later ones.
Re: Seat Airbags
Posted: Tue May 11, 2010 2:33 pm
You'd get a Sausage warning on the dash.
I know what you mean about the flat-shaped older seats, they do look nice BUT I think they could give you a sweaty back because they are dead flat. I don't even want to mention sweaty cobblers; no-one needs that
Re: Seat Airbags
Posted: Tue May 11, 2010 2:47 pm
You could always pull the fuse on the whole system (didn't someone say a while back that they're not part of the MOT?)
Re: Seat Airbags
Posted: Wed May 12, 2010 1:14 pm
by Doggy
steve_earwig wrote:You could always pull the fuse on the whole system (didn't someone say a while back that they're not part of the MOT?)
My bro's 1.9 flew thru the MOT yesterday after I sorted the airbag light:
Attempt 1 - disconnect airbag ecu - no flashing light
it just stays on all the time.
Attempt 2 - out wiv the clocks, swap bulb to door open indicator position, sorted.
Unfortunately, he spent 3 hours trying to get the other rear fog to work. Assumed the lamp unit with no hole for the bulb was a nasty Chinese copy or similar, so carved a hole in it, fitted lamp & it still didn't work.....
Car passed tho, cos ya only needs one
