I have a new knob!
Re: I have a new knob!
Not me, I'm not going to stoop to the depths of poor knob jokes, not my thing.
A flange, however.... 8)
Puggy2
Post by Puggy2 »
No matter how hard I pull my knob it won't come off, I bought the replacement leather but it won't budge any pointers. :oops:
Hack saw or Thor's hammer might help :supafrisk:
Twist slightly and pull. It will come off. It has lugs holding it in place
Puggy2
Post by Puggy2 »
Just received my leather boot but I am not happy it seems too short looking at your picture of it tucked in under the top cap see here http://www.flickr.com/photos/62317743@N05/10775931536/
You seem to have an old style knob from a pre-2002 car. It will only fit the gear knobs like the one I have in my pictures - i.e. the ones that had leather to start with. It does say on the eBay ad that it will not fit those without the leather there in the first place.
Puggy2
Post by Puggy2 »
It did have leather & on it.But I don't have to lift for reverse. It looks just like the picture below the boot in his add.
Oh OK. In that case, it should fit. It did look short on mine as well but it only needs a tiny bit of overhang to tuck the edges in.
Puggy2
Post by Puggy2 »
I have just tried again and if I pull it up enough to fold into the top it is them 5mm from the bottom, I think I may have something for another car.
Very weird. Can you take a picture of the knob without the leather bit on it?
Puggy2
Post by Puggy2 »
here. also if you look at my other pictures you can see the one from his add. http://www.flickr.com/photos/62317743@N05/10776985043/ Just going out for an hour drop back later
Yours is clearly different. Mine doesn't have the neck at the bottom - it's just a circular ball.
Puggy2
Post by Puggy2 »
Bugger in that case anyone with a round knob need a new cover £5.99 just what I paid for it.
All things come to he who waits......
arthritis,
failing eyesight,
deafness,
lower back pain,
short term memory loss,
- in fact lots of stuff you'd rather not contemplate.
Sometimes, though - it's not bad news.
:arrowd:
:arrowd:
:arrowd:
:arrowd:
As I'm too tight-fisted to shell out £31+ for a new knob, this was an unexpected result.
Many thanks to jasper5, who found a 6-speed knob with slightly tired leather that was probably destined for the Pug dealer's bin and diverted it to a good home. :cheesy:
Now, an intelligent person would do some research, (i.e. seek out the coupe club Howto CJ mentioned at the top of this thread), then you would know you can simply prise the inset with the gearchange diagram out of the top of the knob, so no need to take it off the car (or risk damage to your dentures in the process).
I, on the other hand, leapt into action and swapped the knobs over first.....
The following morning, I decided I wanted to replace the leather - it's only £5.99 on e-Bay. Having no idea how to remove it, I finally engaged the brain and looked it up. :oops:
Once separated they look like this....
So, after several hours I achieved the result in the top pic, while someone with a brain could probably have done it in one hit, in about 10 minutes. :roll:
Anyway, I knew you'd all be really excited to hear about this, just like these two.
jonsowman
Post by jonsowman »
Lovely job 8)
