White counters
Malc
White counters
Post by Malc »
The white dials on 406's seem to have been randomly fitted and rarely seen on the 2nd hand market. The 407 white dial template looks exactly the same.
Anyone any idea if I can change a black 406 background for a white one from a 407?
Malc
Re: White counters
Post by Malc »
Well that knock's that one on the head!! Many thanks Username Removed much appreciated.
What's your thoughts on this?
https://www.youtube.com/watch?v=aY20Fn0kQE4
rwb
Re: White counters
Post by rwb »
You're not missing owt.
At twilight they light up pink and are impossible to read against the white. There are also too many graduations on the 407 speedo -- the 406 is much clearer.
trem1
Re: White counters
Post by trem1 »
rwb wrote:You're not missing owt.
Agreed !
Sent from my K013 using Tapatalk
Re: White counters
Malc wrote:The white dials on 406's seem to have been randomly fitted and rarely seen on the 2nd hand market.
If you have an HDi-engined car, then the white dials for these appear to be reasonably easy to obtain.
For petrol-engined models, they're rare as rocking-horse poop. You might be better off getting a custom set made up for you.
I have a set; I was exceptionally lucky!
dirtydirtydiesel
Re: White counters
Post by dirtydirtydiesel »
Malc wrote:Well that knock's that one on the head!! Many thanks Username Removed much appreciated.
That video is by our very own farmer pug, he's very knowledgeable on all things Peugeot
& the reason for doing it that way was because if you fit clocks with millage higher than the one's your
replacing the b.s.i will add both mileages together :roll:
Re: White counters
Mark W ( the Coupe electric guru ) on the coupe forum did fit a 407 rev counter dial to his 406 dials, but it was a faff. The 407 dial is 2mm bigger in diameter so you will need to trim it, and use the rest of the white dials from a late Hdi.
It is possible, but its a lot of work.
ben10241
Re: White counters
Post by ben10241 »
I believe Mark fitted 607 dials.
As for the 407 dials, yes this is not a straightforward swap as the back is not the same shape and oil/temp gauges are reversed. However rev counter and speedometer are the same diameter.
Regarding illumination you should note that full mux 406s have a different system from non and semi mux ones. The colour is integrated to the back on the non mux whereas the colour comes from coloured LEDs on mux cars. Non/semi mux cars are also illuminated by bulbs. Last difference, the needles aren't the same, that is the shaft is bigger in the mux speedometers.
Saying that, I am actually trying to fit 407 dials to a semi mux 406 and I would happily report back the rest of my findings. It involves cutting the 407 rev counter and loads of adjustements.
If you have an Hdi then just get white dials on eBay, they are plenty of those out there and go for ~£25.
