Part fitting
Posted: Mon Apr 24, 2023 12:12 pm
by NinoB
I want to replace 406 rims with others.. I heard that 408 rims do fit in on 406..i don't want 307 type
Apart from 408 rim.. Which peugeot rim type will fit 406 despite they are 17..?
Re: Part fitting
Posted: Sat Apr 29, 2023 11:14 am
by PeterN
Cant help you with that but if you want to retain the good ride I wouldn't put bigger ones on.
Re: Part fitting
Posted: Sat Apr 29, 2023 11:42 am
by GingerMagic
There is a website I used before called Will They Fit.
https://www.willtheyfit.com/
Have a look on here for the 406 dimensions ( pcd and offset - I can't remember exactly ) then look for other Peugeot or Citroen models with the same dimensions.
