I want to replace 406 rims with others.. I heard that 408 rims do fit in on 406..i don't want 307 type
Apart from 408 rim.. Which peugeot rim type will fit 406 despite they are 17..?
Part fitting
Re: Part fitting
Cant help you with that but if you want to retain the good ride I wouldn't put bigger ones on.
Re: Part fitting
There is a website I used before called Will They Fit.
https://www.willtheyfit.com/
Have a look on here for the 406 dimensions ( pcd and offset - I can't remember exactly ) then look for other Peugeot or Citroen models with the same dimensions.
