the 406 rear shockers are they the same on the
saloon and the coupe and estate
rear shockers
Re: rear shockers
Check on Ebay.
Re: rear shockers
was asking as been offered koni shockers
- 1.6 8v
Re: rear shockers
Different part numbers with Peugeot, but aftermarket car part websites show as interchangeable. Plus visually they are 100% identical and the rear axle is identical throughout the 406 range anyway. I would hatch a bet if the price is good and returning them is not too expensive should they not fit.
Re: rear shockers
ive spoke to koni to day and give me measurements the ownly difference it the shokers reboundsupamonkey4x wrote: ↑Fri Jan 21, 2022 6:48 pm Different part numbers with Peugeot, but aftermarket car part websites show as interchangeable. Plus visually they are 100% identical and the rear axle is identical throughout the 406 range anyway. I would hatch a bet if the price is good and returning them is not too expensive should they not fit.
coupe 1000 rebound and 300 bump
estate 1500 rebound and 450 bump
but there they is 4mm diffrent in length
