Power steering fluid
D9406
2.2 16v
Post by D9406 »
After searching the country for a replacement low pressure steering pipe for several weeks, Peugeot fitted 2 types, I have finally got the correct part for my car in my possession.
Question is, how much fluid do I need? The system is completely empty, and Dexron II is correct type to use?
Andy
frog
Re: Power steering fluid
Post by frog »
I've had to top it up once; I used Total Fluide At42 ATF, as mentioned in the user manual on page 25.
I'm not sure how many litres are needed to fill up completely, but I guess it wouldn't be more than 2. Haynes doesn't mention it... :frown:
Current "fleet":
2001 Citroen Saxo 1.6i 8v 100
Previously owned:
2000 406 Sedan 2.0 HDi 90
PeterN
Post by PeterN »
Pleased to hear you got one Andy. 8) I use ordinary dot 3 fluid in mine, don't know how much it holds though, I would think a litre would be plenty.
Sorry, ignore me I'm thinking brake fluid. :oops: :?
