Page 2 of 2
Re: Sits too high at the back?
Posted: Sat Sep 25, 2021 3:38 pm
by MilesS835
So I purchased some 40mm Cobra lowering springs and have fitted the rear, already it looks so much better as it’s slightly more level!
I’m not looking forward to doing the front as from what I gather it’s a bit of a ball ache!
Posted: Sun Oct 10, 2021 6:41 am
It's do-able with the right tools but still a bit of a risk, might be better to find a local garage wiht a proper spring compressor jig thing and take your struts there.
Posted: Sun Oct 10, 2021 9:10 am
by GingerMagic
Definitely a job for someone with the right tools, or that spring could do you an injury...
It's also a good time to replace the strut top bearings seeing as the struts will be removed....
I lowered the back of my 406 by simply filling it with 6 concrete planters..
Good luck with it, the 406 does look better with a little lowering in my eye.
Posted: Tue Oct 19, 2021 12:51 pm
by dirtydirtydiesel
MilesS835 wrote: ↑Sat Sep 25, 2021 3:38 pm
Until you fit the 40mm lower front springs then back to square one
You just need some good spring compressors (don't try without them)
You can cut your old good one (like your broken one) before taking off the strut top & yes 100% fit new strut top
bearings while your in there.
