Sits too high at the back?
MilesS835
Re: Sits too high at the back?
Post by MilesS835 »
So I purchased some 40mm Cobra lowering springs and have fitted the rear, already it looks so much better as it’s slightly more level!
I’m not looking forward to doing the front as from what I gather it’s a bit of a ball ache!
1998 Diablo red 406 V6 estate
1981 DeLorean
Can't buy parts when it's all on petrol! :lol:
It's do-able with the right tools but still a bit of a risk, might be better to find a local garage wiht a proper spring compressor jig thing and take your struts there.
1991 Yamaha TDM850 - it's fixed! Shame about the rider...
2008 Toyota Recall4 2.0 VVTI ATM (Anti-Theft Mechanism) LHD JTMBH31V90D007261 - flimsy piece of crap.
1953 Matchless G3LS - it weighs a ton!
Definitely a job for someone with the right tools, or that spring could do you an injury...
It's also a good time to replace the strut top bearings seeing as the struts will be removed....
I lowered the back of my 406 by simply filling it with 6 concrete planters.. :cheesy:
Good luck with it, the 406 does look better with a little lowering in my eye.
dirtydirtydiesel
Post by dirtydirtydiesel »
MilesS835 wrote: Sat Sep 25, 2021 3:38 pm So I purchased some 40mm Cobra lowering springs and have fitted the rear, already it looks so much better as it’s slightly more level!
Until you fit the 40mm lower front springs then back to square one :wink:
You just need some good spring compressors (don't try without them)
You can cut your old good one (like your broken one) before taking off the strut top & yes 100% fit new strut top
bearings while your in there.
2002 110 HDi estate, Rapier in monaco blue! ( found quite a bit more power :cheesy: ) for sale after I've sorted the airbag light :(
