Page 2 of 2
Re: MOT failed need part advice
Posted: Wed Oct 14, 2020 7:34 pm
by sturose
steve_earwig wrote: ↑Wed Oct 14, 2020 5:24 pm
The antirollbar link is plastc (I think) and has a balljoint each end, we can't look up the parts diagrams any more so I can't tell you the proper name for the other link but it controls track (& trace?) and camber. A quick search later... yeah, there are loads of sites listing it as the antirollbar link. Horizontal link rod? That sounds better.
There is a ball joint one end of it but calling it "upper" rather implies there's a lower, and there aint.
And the lesson is: Always get the tester to show you the part 'cos a lot of the time he might be calling it the wrong name.
That's what confused me, I looked for a "lower" and "upper" joint. If anything I would define this joint as "lower" anyway as it's at the lower end of the bar!
I would have got the tester to show me if I could have booked in at my usual garage but they're fully booked to the middle of next month. The one I used is following the covid rulebook to the letter and I wasn't allowed anywhere near them!
Posted: Wed Oct 14, 2020 8:45 pm
by dirtydirtydiesel
steve_earwig wrote: ↑Wed Oct 14, 2020 7:11 pm
dirtydirtydiesel wrote: ↑Wed Oct 14, 2020 6:43 pm
Steve, my tester mark's the failed part's with a yellow paint pen.
That sounds like a great idea, unless it's a part you can only see with the car up on a lift...
You can, pop of the rear wheel & it's staring at you.
There nothing on my car I can't get to without a four poster lift
I'd love one, but then I'd love the workshop for it to go into too
Posted: Wed Oct 14, 2020 8:48 pm
by dirtydirtydiesel
sturose wrote: ↑Wed Oct 14, 2020 7:30 pm
dirtydirtydiesel wrote: ↑Wed Oct 14, 2020 6:47 pm
Look up, I did say no 13 in the diagram that Steve posted up.
Yeah I noticed it was the same part.
dirtydirtydiesel wrote: ↑Wed Oct 14, 2020 6:50 pm
Don't forget what I said about the elliptical washers & bolts, you will need them (trust me)
Yeah, it's straight forward enough, but you will need to get proper rear wheel alignment done after.
Elliptical washers and bolts? Any idea of sizes, quantities etc?
Yeah, two bolts with built in washers, two washers & two nuts.
You can get em off fleabay.
Item no 221918729342 or search for Rear suspension eccentric bolt,nut,washer kit Peugeot 406.
Right enough helping people out,
I've got my airbag/bsi issue's to get to the bottom of
Posted: Thu Oct 15, 2020 5:47 pm
by sturose
dirtydirtydiesel wrote: ↑Wed Oct 14, 2020 8:48 pm
Great thanks. The help is much appreciated. Good luck with your own issues.
