strut top knock
CHRISHDI110
strut top knock
Post by CHRISHDI110 »
for a few months now ive had a slight knocking from my front suspension so bought a pair of drop links as it sounded like em. jacked front up today and levered under tyres but both links were fine!! i did notice that the top of both front struts were knocking where they bolt to the arch. does that sound like the bearings ive read about on here or summert else? the manual doesnt mention bearings so will i need to change the whole strut?
1986 Lotus Excel SE
2002 406 hdi 110
406, better late than never.
PeterN
Re: strut top knock
Post by PeterN »
I did replace the strut top bearings on one of mine but that's because they were seizing up rather than knocking. The only other knocks I have had are from a track rod end or the bottom ball joint.
CHRISHDI110
Re: strut top knock
all other joints are ok. with the wheel off today i levered the hub up and down and you can hear it knocking at the top of the strut near where it bolts to the arch. you cant see any movement, just feel and hear it. can you get to the bearings through the top in the engine bay or do you need the strut out?
1986 Lotus Excel SE
2002 406 hdi 110
Re: strut top knock
You need to remove the strut.
CHRISHDI110
Re: strut top knock
Ok, Cheers. :wink:
1986 Lotus Excel SE
2002 406 hdi 110
Gilly
Re: strut top knock
Post by Gilly »
Hi there,
Have a look at your struts and springs also to make sure a spring has not broke or strut blown.
406 springs are very long and can often break without the driver even knowing.
As you are changing top mounts you will have these all disassembled anyways 👍
2001 HDI 90bhp - current daily
