16mil rear caliper bolt (bog one on bottom)
Vespapx177
Post by Vespapx177 »
Hi
Does anyone know if the slider kits from Big Red come with new bolts as I've rounded mine off, the hex one is fine, it's the bottom one or can I just go screwfix and buy 900 for a pound? so 16mm head, any idea how long? as mine is stuck in so can't measure it :-(
Re: 16mil rear caliper bolt (bog one on bottom)
I don't have one to hand, but is it possible to carefully remove the bolt from the other side to compare?
You could probably get a couple of replacement bolts from ade1122 from the 406 coupe forum, also found on eBay as BBautos
https://rover.ebay.com/rover/0/0/0?mpre ... 3111224533
His name is Adrian, and a pleasure to deal with.
Vespapx177
Cheers, I'll drop him an email via fleabay
