is it dying?
Posted: Sun Mar 12, 2017 10:00 pm
by straggler
I'm on an extended European road trip in my 96 1.9 XUDT. All has been well (apart fora few niggles) until today. I was driving at about 65mph when the steering wheel started shaking just like a wheel was out of balance. It was accompanied by a vibration and a humming noise. I put this down to the road surface (out of hopeless optimism) but it started doing it again about an hour later. I pulled over and checked wheel nuts, that there was nothing wrapped around the driveshafts etc but couldn't see anything obviously wrong. But the front driver's side wheel was hot.
Anyway, it carried on like this until I turned quite a sharp turn. There was a sharp-pitched grinding noise for about two seconds and then a clonk and everything now seems fine. Any ideas? Nothing's leaking, grinding or otherwise broken, as far as I can see. But I am as far from the UK as I'm going to be on this trip so will head home if it sounds like it might be a nasty.....
Re: is it dying?
Posted: Sun Mar 12, 2017 11:16 pm
by PeterN
Odd one, could be the o/s CV joint failing but I have never heard of those symptoms before. Possibly a stone jammed in the o/s front brake? I would suspect that whatever happened had now cleared, I would just continue driving it and see what happens.
Re: is it dying?
Posted: Fri Mar 17, 2017 7:25 am
by barbaren
Front wheelbearing.
If the joints are failing, it will make loud clonk noises
Re: is it dying?
Posted: Fri Mar 17, 2017 7:51 am
Sounds a bit like a sticking front caliper but if everything's now ok just take it easy and keep checking the wheel for heat. Ideally if it is that problem you'd need to strip the brakes, clean everything and reassemble with copper slip on the caliper slide pins etc.. easier said than done when you're 'on the road'.
Re: is it dying?
Posted: Fri Mar 17, 2017 9:59 pm
by dirtydirtydiesel
I agree with welly
Does sound like a sticking caliper, a wheel bearing wouldn't make the wheel hot.
But don't use copper grease on the slider pins,
It dries out & causes the caliper to stick prematurely
Re: is it dying?
Posted: Mon Mar 20, 2017 10:09 am
dirtydirtydiesel wrote:I agree with welly
You're surprised?
Re: is it dying?
Posted: Fri Mar 24, 2017 1:22 pm
by Bailes1992
Sounds like the exact symptoms I had in my 1.9TD when the inner CV joint failed. Maybe you have a slightly sticky calliper too as a coincidence.
Re: is it dying?
Posted: Fri Mar 24, 2017 2:01 pm
by straggler
Thanks for the posts. Discovered it's a binding front brake.
Now I'm back in the UK I want to take the caliper off to give it a clean. Can someone talk me through this? I've changed pads before but don't want to mess with anything ABS-related.
Thanks!
Re: is it dying?
Posted: Sat Mar 25, 2017 12:07 am
by dirtydirtydiesel
To be fair if your asking that I'd probably say stay away
These are your brakes, the single most important thing on your car.
Do not mess if you're unsure.
If you still wish to go ahead then....
The abs is no problem, you will need to clamp the flexible line to prevent fluid loss before removing the caliper
then with the caliper on the bench remove & inspect the slider pins ( usually siezed) followed by the piston.
Both repair kit's are available on ebay, but it might be better to just buy a refurbished caliper
Bleeding is straight forward unless you have drained the whole system
Always start with the caliper furthest away from the master cylinder, working your way to the closest.
Re: is it dying?
Posted: Sat Mar 25, 2017 8:06 am
by straggler
dirtydirtydiesel wrote:To be fair if your asking that I'd probably say stay away
I agree! I've booked it in with my local garage to have it done. Don't have the enthusiasm (or the torx sockets) these days for fiddly jobs that can go badly wrong. But i am going to silicone the sunroof and back lights to stop the leaks!
