hi, ive just found and joined this forum and looking for some advice, I have a 406 110 hdi estate, previously having the 110 saloon and early 1.9 estate, I love my car however it has developed a tendency recently to not self centre when turning left or right fluid level is fine tyres good and no nasty noises so I'm a bit stumped as to what it might possibly be, any pointers would be greatly appreciated
thank you
steering not self centering
Re: steering not self centering
Hi Mark, welcome to the club.
You've checked the obvious things but next on the list would be the strut top bearing....
They can wear out, which puts extra stress on the front spring which 'may' snap one day ( normally only at low speeds ) so its worth getting checked.
Hi Mark & welcome aboard.
As GM says, strut top bearings are likely to be the cause. If you can get both front wheels off the ground, you should be able to hear something from wherever it's sticking.
2006 BMW e61 535d m-sport
run's for cover
going to check strut top bearings out tomorrow but is it possible it could be the pressure switch, ive also been told there are two types of steering rack, variable and non variable, whats the difference and how do I know what type mine is thank you
ive been told it could also be a pressure switch, is this a possible cause ? also I have found out that there is variable and non variable power steering, how do I know what type mine is, I'm going to investigate the strut top bearings tomorrow or Tuesday, thank you for any advice
Hi, if you send me your VIN number I can check to see if your car has variable power steering or not.
