Page 2 of 5
Re: Backplates
Posted: Sat Feb 20, 2016 3:27 pm
by ridgie74
forgive my ignorance, but pictures of some new back plates don't show the calliper mounts... is it easy to remove and reuse these from the old plates?
Re: Backplates
Posted: Sat Feb 20, 2016 3:52 pm
by GingerMagic
I think ( but I'm not 100% sure ) that the ones without the caliper mounts are for rear drums only, not suitable for rear disc/drum set up.....
Re: Backplates
Posted: Sat Feb 20, 2016 4:21 pm
by ridgie74
servicebox for my car (hdi 90) shows the backplates with no caliper mounts, and it has rear discs. strange.
Re: Backplates
Posted: Sat Feb 20, 2016 4:23 pm
by GingerMagic
Okay - there must be a way to get the mounts off then, but when I did mine a few years back I didn't see any bolts or anything?
Edit; Service box also shows mine without the caliper mounts.....
Re: Backplates
Posted: Sat Feb 20, 2016 4:33 pm
They're supposed to be part of the backplate. That could be tricky
These Kolkkerholm backplates have the cut out for the calliper but there's no mention of calliper mounts
Looking at pictures of the backplate it looks like they're are only 2 (real) rivets holding them together - I wonder if there's enough clearance to use a nut and bolt
viewtopic.php?f=27&t=20047&hilit=backplates#p201249
Or maybe they0d be ok if everything's lined up straight as the bolts pass through both.
Re: Backplates
Posted: Sat Feb 20, 2016 8:19 pm
by jasper5
I think it's either/or there Steve.
You can grind off the rivets on the old backplates and fit the old caliper mounts to the new backplates using bolts or fit them without using bolts in the rivet holes...there is plenty of clearance for bolts to be fitted through the backplate.
Re: Backplates
Posted: Mon Feb 22, 2016 1:39 pm
by ridgie74
spoke to carz2.co.uk and they confirm the backplates don't have the calliper plates. I took a deep breath and just ordered new ones from Peugeot. feeling strangely elated and a bit depressed at the same time...
Re: Backplates
Posted: Mon Feb 22, 2016 1:53 pm
So it turns out they're not much of a bargain at all
In fact they turn out to be way too expensive, considering half of them is missing.
A mixture between a weight off of your mind and the realisation that you've been wallet-raped at the dealer's again. I know the feeling
Re: Backplates
Posted: Mon Feb 22, 2016 4:16 pm
by jasper5
ridgie74 wrote:spoke to carz2.co.uk and they confirm the backplates don't have the calliper plates. I took a deep breath and just ordered new ones from Peugeot. feeling strangely elated and a bit depressed at the same time...
You can easily swap over the caliper brackets from the old ones and fit them to the new backplates!
Re: Backplates
Posted: Mon Feb 29, 2016 8:28 pm
by SwedishLinus
jasper5 wrote:ridgie74 wrote:spoke to carz2.co.uk and they confirm the backplates don't have the calliper plates. I took a deep breath and just ordered new ones from Peugeot. feeling strangely elated and a bit depressed at the same time...
How easy is this Jasper? My handbrake got stuck because that the spring/bolt that holds the break shoes in place didn´t kept its place in the brake shield. So could i buy the Klokkerholm splash shields and use my old mount?
Re: Backplates
Posted: Mon Feb 29, 2016 10:03 pm
by jasper5
SwedishLinus wrote:jasper5 wrote:ridgie74 wrote:spoke to carz2.co.uk and they confirm the backplates don't have the calliper plates. I took a deep breath and just ordered new ones from Peugeot. feeling strangely elated and a bit depressed at the same time...
If you read my earlier post I explain how easy it is.
In this link the photos of the new backplate shows only 2 rivets holding the caliper brackets to the backplate...you can easily grind the rivets off or drill them out.
You can then use 2 nuts and bolts or even just bolt the backplates on without using 2 nuts and bolts...just use the backplate mounting bolts.
Re: Backplates
Posted: Thu Mar 03, 2016 5:21 pm
by SwedishLinus
If i were to use the old caliper mounts, where can i get the backplates as cheap as possible? The cheapest ones i have found in Sweden are about 60 pounds each, and thats without the mounts!
Re: Backplates
Posted: Thu Mar 03, 2016 6:59 pm
by grasmere59
I think thats the best price your going to get for 406 backplates.
Re: Backplates
Posted: Fri Mar 04, 2016 11:48 am
by SwedishLinus
So they arent cheaper somewhere in the UK?
Re: Backplates
Posted: Fri Mar 04, 2016 5:42 pm
Only second-hand (there's been a lot of overpriced rubbish on ebay lately
Mind you there's always Ade1122 over on the coupe club who mostly breaks coupes, I think he charges about 25 pounds and doesn't sell rubbish. He has the same user name on ebay but I don't know how to find that.
