words of warning 406 owners
To all 406 owners.be aware of the handbrake shoe retaining pins they have a tendency to pop out into ur drus causing a lot of damage I had two of mine go today chipping my abs ring now after repair my abs kicks in whenever it feels like under braking usually low speeds I suggest u do what I have done and use a nut and bolt with washers and springs instead to prevent this issue now I have a massive job of changing the ring bastard car lol
Les medecins choisissent www.viagrasansordonnancefr.com traitement efficace
Re: words of warning 406 owners
Can't afford the fix at mo should I remove abs fuse any advice on changing one on rear
Just looking at prices they seem maddest enough for a hub and ring but how many teeth should it have. Also does anyone know where I could find some replacement backplates going to.do the lot while I'm there
Sorry to hear that, something else to worry about I guess
Pull the fuse I guess, you'll probably have a warning light up. Be very careful with the brakes too, I suspect modern manufacturers don't bother much with ballancing the brakes any more, relying on the ABS to sort it out, so I'd be worried about brakes locking up, especially the rears.
I think ade1122 (coupe club or ebay) will be your best bet for the backplates.
29 teeth for a D8, 48 teeth for a D9.
How do I know if I got d8 or 9
Your HDi 90 is almost certainly a D9, (99-04) - they have clear headlights and black honeycomb grille.
D8's, (95-99), have frosted headlights and a slatted grille in the body colour.
Yh d9
Hi guys anyone tell me the size of hub nut so I can get a socket for it plz
Rear one is 40mm, front one is 35mm.mikesthedaddy1 wrote:Hi guys anyone tell me the size of hub nut so I can get a socket for it plz
