Front ARB Bushes - help!!!
gumby6371
Post by gumby6371 »
I had a quick go at changing these last night and promptly gave up, access to the retaining nut on my 2.2 is ridiculous from the wheel arch side and stupid from underneath.
I forgot to take any pics last night so the more eagle eyed may recognise this from MJB's clutch change how-to;
Can someone confirm if the rearmost bolt of the cluster of 3 goes straight through to the ARB clamp and can be undone from underneath?
Trying to judge by touch the nut didn't seem to line up with the subframe bolt but I only had the car on a stand not the ramps and couldn't see/line things up properly.
Hopefully that makes sense?
markw
Re: Front ARB Bushes - help!!!
Post by markw »
Not done this myself, but Servicebox shows a separate nut for these.( ie not captive) It's on a lovely long 115mm bolt too with lots of exposed threads..... :roll:
You can see the opposite side one in your pic.
I would guess the way to do these is to get a long reach socket on the nut while turning the bolt head from below...... :?:
Oddly, Servicebox shows the bolt uppermost, pointing down with the nut underneath, which can't be right judging by the length of that bolt.
gumby6371
Post by gumby6371 »
Mark,
Thanks for the quick response, that's what I needed to know just wasn't sure if the visible bolt head corresponded to the nut on the clamp.
I can get my 19mm off set ring spanner on the nut from the wheel arch which is a good job as you need the mother of all deep sockets to fit over the incredibly long bolt.
dirtydirtydiesel
Post by dirtydirtydiesel »
gumby,
When I did mine I needed to remove the droplinks from the anti rollbar first & yes a ring spanner on the nut & a socket on the bolt head.
You'll soon find out why the bolts so long :wink: , it's so you can get it on to clamp up the rubber bush tight, oh & I think you'll strugle to do this with out jacking up the front end :roll: .
Best of luck DDD.
gumby6371
Post by gumby6371 »
Cheers DDD, as much as I appreciate MarkW checking servicepox is always nice to hear from someone who's done the job.
I only had the car up on my small axle stands as my £20 jack doesn't lift particularly high hence the lack of room under there.
I think I'll disconnect the drop links and then put it on the ramps to give me some more elbow room. I never like giving stubborn bolts the heave ho when it's on stands as my drive isn't the most level.
Just having a look at the job the other night I had the axle stand + jack + wheel under the sill - just in case!!!!
