The car had replacement rear pads and shoes just before i bought it and the previous owner did say the handbrake needed adjusting, and it has been undone quite a long way previously, probably to overhaul and replace the rear brake bits, as its adjusted right out so the threaded bar is flush with the end of the metal hex part thats connected to the white plastic piece, and you can pull the whole assembly around because its so slack, which explains why the handbrake goes up what feels like about 20 clicks before it finally holds the car.
So im just wondering how im meant to adjust this, im guessing i just grip the smooth part (or a threaded bit thats far enough out of the way for it not to matter) of the cable with molegrips and then undo the lock nut and adjust, but i still dont know what im to do about the fine tuning of it using the lever adjustment as i have no way of adjusting that bit.
Anyone got any ideas?
Many thanks
