Leaky power steering HP pipe/fitting
Posted: Thu Apr 10, 2014 12:07 pm
I have a slow leak which is causing my HP pipe to be wet. The leak is in the fitting between the brass pipe and the rubber hose. The replacement part is pretty pricey, at more than €200.
Any of you tried to seal such a leak, or have any suggestions on how to fix the existing part?
