Rear tyre wear
Rear tyre wear
So the new daily I have is a 406 saloon, HDi 90.
The inner edge of the rear tyres is completely destroyed, like down to the metal and some, can't believe I missed it when I picked the car up, but it came with plenty of fuel so I guess that offsets the cost of a pair of part worns..
My first thought is the tracking is out, as it also feels a bit tail happy and "wobbly" in corners. Anyone got any other suggestions??
I've jacked it up to swap wheels and all feels solid, so no shot bushes etc..
Re: Rear tyre wear
If there's nothing loose or worn, someone has probably changed the upper links without ensuring the camber is reset correctly.
Best bet is a 4-wheel alignment, (once you're sure theter are no faulty suspension components).
Have a search on the forum.
Re: Rear tyre wear
Ok, so can the rears actually be tracked? My local garage insists not, and tbh I can't see how. Confused!?!
Re: Rear tyre wear
yes the rears can be tracked
theres a large bolt that turns a funny shape washer that does it
as said you need a 4 wheel aliament center costs about 50 pounds
if your local garage dosnt know this might be time to find a better garage
Re: Rear tyre wear
Heh, yeah I'll go elsewhere. I'll look myself first, it's on the inboard end of the tie rod/stabiliser thingy, right?
Re: Rear tyre wear
Yes, it's at the inboard end - the bolt has a kind of eccentric head/integral washer, as Nigel was saying.
I'll try to post a diagram later or link to an appropriate post later, unless someone beats me to it, (which is OK by me)!
Re: Rear tyre wear
Ok, that makes sense, I'll get my new tyres fitted at kwik fit, as they'll do a free tracking check, gotta Be worth it, right?
Re: Rear tyre wear
NOjonny81191 wrote:Ok, that makes sense, I'll get my new tyres fitted at kwik fit, as they'll do a free tracking check, gotta Be worth it, right?
By all means get your tyres there but I dout they have they right gear/skill to do thisjob
where in the uk are you?
Re: Rear tyre wear
omega wrote:NOjonny81191 wrote:Ok, that makes sense, I'll get my new tyres fitted at kwik fit, as they'll do a free tracking check, gotta Be worth it, right?
Sorry, I didn't mean I'd get them to do the tracking, just check it and confirm it's out. I get on reasonably well with the guys there anyway, so I can "supervise"
Re: Rear tyre wear
Have a look at this post: viewtopic.php?f=27&t=14638&p=138145&hil ... er#p138145
There may be better explanations, but I think this will serve
