rear wheel geometry measurement
Posted: Sat Nov 10, 2012 6:01 pm
by jhc928
Hi does anyone have the rear wheel camber/ toe in measurements for a hdi estate on15 ins wheels
Re: rear wheel geometry measurement
Posted: Sat Nov 10, 2012 6:32 pm
by dummysock
Hi
Try
H2 (mm) 150
Camber -1° 50' ± 30'
Track (mm) 1,5 ± 0,5
ODM (mm) 208
REAR SUSPENSION GEOMETRY (toe is adjustable)
Posted: Sun Nov 11, 2012 7:24 pm
by jhc928
thanks did find a posting on the net gave the same as you so set it to that , its only that having yo get the heat on the inner bolt it torched off my marks ,but saying that when i finished setting it up the bolt was in the position that someone on here had described as having the slot just at the top just slightly to the outside of the car ,spot on
Posted: Sun Nov 11, 2012 10:31 pm
by dummysock
I have marked the bolts and then changed the rear top links. I have then had a 4 wheel alignment carried out and the rear wheels are still out.
Lets face it since we are only dealing with millimetres, if the top links are a different length by millimetres then the rear tracking can be wrong. I now always err on the side of caution and get the tracking done ( saves 2 x £60 tyres )
