I'm trying to replace the rear track rods on my 51 plate 406 estate; I've removed the wheel, marked everything and removed the nut from the balljoint end and removed the nut from the in-board grooved bolt - and now I'm stuck.
I cannot seem to get the balljoint end up out of the hub carrier(?), I've tried it with the suspension spring compressed and uncompressed (with a jack) and I've tried smacking it with "the Clarkson" (my favourite, heftiest hammer).
Neither can I get the grooved bolt out at the in-board end of the rod - I've tried "undoing it" but it just rotates (adjusting the track as it does so) and I've tried a few experimental smacks with the Clarkson there too - to no avail.
I even dug out my old ball joint fork - but it doesn't seem to help either.
The grooved bolt - should this "un-screw" or should it slide out?
Any and all advice, shoulders to cry on and a good "there-there" welcome.
thank you
