Rear creak - ideas and rear shock removal?
Posted: Sun Aug 19, 2012 8:33 am
From inside the car there is what sounds like a knocking noise from o/s/r.
Outside it's more of a creak, so got car up in the air with wheel of and jacked the hub. As it compresses, it feels a bit sticky, as it moves past the sticky bit it creaks.
I did get a pry bar and check for play on every link/arm but found nothing. Prime suspect at the moment is the shock, although can see no damage when fully extended.
To rule out the shock was going to remove it and take for a drive - if quiet then know that is it. Is it as simple as undoing top and bottom to remove?
Otherwise are they any other bits to check, given the lack of play, or is this meaningless?
