Information Needed ....
After singing the praises of my 406 for passing the mot , today i have
picked up a self tapping screw in front tyre and while tyre man was
looking at this found a split abs ring on nearside front . I've been on
service box but this part is not listed individualy so anyone got any
advice or info please :)
Found some on fleabay , different sizes how do you which is right one :roll:
Re: Information Needed ....
Pug only sell them complete with the driveshaft (the swines). I don't know about the size (measure?) but I did spot a how to on the coupé club the other day on how to change them without removing the drive shaft (saw in half, araldite basically)
That saw in half info is usefull , will have to pull if off see how big it is ...
DiscoPol
Shiny New C5 2.2 Bi-turbo!
Post by DiscoPol »
puggy wrote: will have to pull if off see how big it is ...
Fnarr fnarr fnarr,
you cant seriously think you of all people can say something like that without me finding it incredibly funny/smutty can you?
now about this thrashing i should have had when i was younger...............................................
steve_earwig wrote:Pug only sell them complete with the driveshaft (the swines). I don't know about the size (measure?) but I did spot a how to on the coupé club the other day on how to change them without removing the drive shaft (saw in half, araldite basically)
Good idea that.
ive seen these a.b.s rings repaired before and its worked.
Wouidnt J.B weld be better than Araldite tho as it sets like metal
Cheers lozz , heard about j b weld will give it a try when i get new ring ..
Fnarr fnarr fnarr,
I might have bloody known you would smutify something disco !! like a bloody proof reader you are :P
and as regards the thrashing i meant with a leather belt and buckle across the arse not the thrashing
you were thinking about :twisted:
puggy wrote:Cheers lozz , heard about j b weld will give it a try when i get new ring ..
its excellent stuff,
its just a case of mixing it right or it takes an age to set,
