Page 1 of 2
Rear Suspension Clunk over bumps
Posted: Sun Sep 11, 2011 6:11 pm
by tvbarker
My rear suspension makes a clunking noise over large-ish bumps, mainly at slow speed - I think it's the drivers-side.
There don't appear to be any issues on even ground, even a speed much as the motorway.
It doesn't feel to be that much of an issue but concerned it'll be an MOT fault and would rather sort the problem now.
Can anyone advise on what might be causing the problem, I'm a total newbie to but would like to fix this if possible.
Feel free to ask any further information.
406 HDi - Y - Saloon
Re: Rear Suspension Clunk over bumps
Posted: Sun Sep 11, 2011 9:30 pm
by ally406
There are various bits and pieces that can wear on the rear suspension, but the first port of call are the rear drop links. These are the plastic bars that connect the roll bar to the hub assembly. Pop the wheel off and give it a firm tug and see if there's any play. If there is, that's your problem. Luckily they are easy and cheap to replace.
Posted: Mon Sep 12, 2011 11:25 am
by mjb
I'd suggest an even easier first port of call - the exhaust mounts. Rubber lumps with two holes in - one hole for a hook in the body and another hole for a hook on the exhaust. Piece of cake to find and change, and only a few quid.
Posted: Mon Sep 12, 2011 12:50 pm
by teamster1975
Other thing to check is the antirollbar bushes.
To be honest if you're going to be sorting it yourself I would replace the ARB bushes, ARB drop links and the top stabiliser rods as they all wear out, especially if cheapies from ebay were last fitted!
Posted: Tue Sep 13, 2011 8:19 am
by robb
I second MJB I had a similar noise ,one of the brackets had snapped off the back box :shock:
Posted: Wed Sep 14, 2011 9:46 pm
by tvbarker
No luck guys. Took the wheel off and no sign of damage (apart from a rusting disk)!
Same with the exhaust, looked around and gave everything a good shake but couldn't spot anything. I'll have another play tomorrow and attempt to report further information.
Cheers.
Posted: Wed Sep 14, 2011 9:50 pm
by ally406
Another thing to check is the lower arm rose joint bushes. Jack the car up and grasp the wheel firmly and see if you can rock from side to side or up and down. I had exactly the same thing, I thought it was a knackered wheel bearing at first. These are a pain in the arse to change unfortunately.
Posted: Wed Sep 14, 2011 9:51 pm
by tvbarker
Took some photos. Might help a little?
Posted: Wed Sep 14, 2011 9:52 pm
by tvbarker
Posted: Wed Sep 14, 2011 9:53 pm
by lozz
AH.
this sounds familiar,
only took me 6mths or so to find the clunks on my old 406.
Re: top links, how did you check them,
did you check them with the wheels off the Ground ?
if so check them again with the wheels on the ground, :wink:
Posted: Thu Sep 15, 2011 10:32 pm
by mjb
I'm no suspension expert, but whatever's in 3 (shock absorber?) looks well past its best
Posted: Thu Sep 15, 2011 11:48 pm
by ally406
That's the shock dust cover. Mine are at least as bad, but the actual shock is just fine.
Posted: Sat Oct 15, 2011 8:04 pm
by Blue2
Hi, I have had the same problem with the clunking over bumps. I have just replaced the rear shocks, drop links and stabilzer bars. The clunk is not as bad by far, but whilst doing it I found that the bush in the hub was not very good, so that is the next thing on my list ( I'm sure that will sort it all together ) hope this helps
Posted: Sun Oct 16, 2011 11:53 am
by ally406
The lower rose joint bush, you'll have fun with that :wink:
Posted: Mon Oct 17, 2011 2:48 am
by STALLED
teamster1975 wrote:Other thing to check is the antirollbar bushes.
+1
And the rear drop links wear! Replaced both on my car - quiet as!
