Leading Arm Bushes
ally406
Leading Arm Bushes
Post by ally406 »
I'm trying to rebush the rear leading suspension arm, but it's proving a pain. I got the old bushes out after a couple of hours, but I can't get the new ones in. I've got one in so far then it got stuck. I've left the arm at a garage to see if they can press it in, but the chap wasn't optimistic given the funny mushroom shape of the bush. Has anyone attempted this?
ally406
Re: Leading Arm Bushes
Post by ally406 »
Well, finally got this unpleasant job done. Garage got them pressed in but said it was a pain in the arse. The 3 bolts that hold the bracket in were little more than finger tight :shock: They're supposed to be 100nm, I don't know if they worked loose, or if someone else had forgot to torque them up. Might be worth checking next time you are under yours.
406loon
Post by 406loon »
I believe there is a specific tool for this which means you can do the job in situ. Its about £45 off ebay.
53' 406 2.2 HDi SE saloon - Samarkan Blue
Coupe strut brace-BMC CDA-Bosch Aero wipers-2.5'' T304 fap back exhaust-de-cat/dpf internals-EGR blank-180bhp remap-Ultra Racing rear lower brace-Poly engine mount- Brembo calipers-braided hoses-LEDs-55w Xenon 6k kit-nightbreaker plus main+fogs-LED sidelights
ally406
Post by ally406 »
Hi Loon, are you not thinking of the tool for the lower arm rose joint bushes? I've already done those, not too bad once the assembly was off the car. I'm talking about part number 15 in the picture:
406loon
Post by 406loon »
..Thanks for clearing things up with a diagram. Looks like a pain in the ass...which will be fun when I get all the bushes out of mine so I can get poly ones made up.
