RAPIER BRAKES
Posted: Wed Aug 24, 2011 8:45 pm
by parcelman
just noticed the last couple of days when i press the brake pedal i can hear the pads making contact with the disc,like a metal tinny noise.the pads and discs all four corners were only fitted five months ago,any idea chaps.
Re: RAPIER BRAKES
Posted: Wed Aug 24, 2011 9:25 pm
by iangt4
have you actually checked the pad thickness, if you have a seized caliper then you will found out it will wear out the inner pad very quickly. it could possibly just be the back plate thats rubbing slightly. but the rear calipers are prone to seizing. time to check before they take out your discs
Re: RAPIER BRAKES
Posted: Thu Aug 25, 2011 7:11 pm
by parcelman
all pads and discs are fairly new (5 months old ) on all four corners
Re: RAPIER BRAKES
Posted: Thu Aug 25, 2011 7:17 pm
by omega
parcelman wrote:all pads and discs are fairly new (5 months old ) on all four corners
but the calipers arnt.
