Upper rear suspension stabiliser bolts
Posted: Tue May 24, 2011 8:39 am
by Antfoote
Hi this is my first post, I hope I'm clear in what I'm looking for. My hdi 90 rapier estate needs new rear stabiliser bars, the ones that can adjust camber. I have the bars but the old ones need grinding off so I need to find somewhere that sells the bolt and washer. The washer has a groove in it as does the bolt to adjust the wheel camber. Thanks for looking and I hope I've been clear enough. Cheers. Ant
Re: Upper rear suspension stabiliser bolts
Posted: Tue May 24, 2011 9:04 am
by Gary406
i got a set of bolts and nuts from the dealers , they only cost about £6 or so,
take a photo of the bolt (top end) so that you put the new one back the same way. this way you wont need a 4 wheel allignment.
to be honest i think this bolt will be dealer only.
Posted: Tue May 24, 2011 10:18 am
by plod
Appears to be
10: 5132 59 Screw
11: 5169 04 Washer
77: 6936 86 Nut with base
Posted: Tue May 24, 2011 10:22 am
by Antfoote
That's brilliant thanks. I have called my local dealer. They are calling me back but think they are called camber adjustment bolts.
Posted: Tue May 24, 2011 11:18 am
by plod
Sounds reet
