SQEALING REAR BRAKES
Posted: Sat Apr 30, 2011 2:22 pm
Hi
Having a problem with the rear pads. A while ago i took jaspers advice when i had this problem before and filed chamfers on the pads cleaned everything up etc put it back together and it was fine for a long time. Well now the problem is back i cleaned them up again about a week again and put copaslip on them. It only sqeals when its in reverse gear. When you're going forward its fine. The pads i've got in just now are down to about halfway 5-6mm i'd say. I had a thought i've got a set of shims that i bought from peuegot ages ago. I didn't fit them when y these pads went in because it was a real tight fit but now they are down to halfway i might just try them and see if they make any difference. I can't remember which way round they go i'm assuming the metal side of the shim goes next to the pad and the other side with the rubber surface goes against the caliper? I think thats right? Any help would be appreciated. The sqealing brakes need to go......Lol
