Where to put axle stands on rear of sri?
i tried putting my car on axle stands earlier when looking at rear brakes and i couldnt see anywhere to put them? i jacked the car up on the suspension arm i think it is, but couldnt see where to put the axle stands, i tried on the axle but the car just went down as its part of the suspension
Re: Where to put axle stands on rear of sri?
In the handbook of my 2000 model i am sure it says to put them under the sill about where the scissor jack would normally go.
yh the sill seems to bend and creak tho, feels like its gonna bend and break
your on the wrong part or your sill is not very well then, theres a kind of "tab" that sticks down, bout 3" long, stick em on tat bit.jason1987 wrote:yh the sill seems to bend and creak tho, feels like its gonna bend and break
1997 2.1TD executive estate - mmmm, lovely
i dont know, it just looks like it cant take the weight, the sill is a thin bendy thing, and the jack is a round piece not like the scissor jack
I never like putting it on the sills, I worry it's going to flex something and then rust, rust, rust. On the D8 the trailing arm is tubular and if you put the stands near the front bushes it sits on them a treat. On the D9 it's cast and triangular so not very stable 'cos you can't get the stands central. You can put them under the spring seats but, seeing as how this is the best place to put a trolley jack, it's not very easy. I tried it once, putting the jack towards the centre of the car on the lower arm but, after I had an ohfuskinghellshitshitshit moment when the car started to slide off it, I'll not be trying it again.
I just lump it in 1st with chocks under the front, jack it up high on one sill, put an axle stand under the other, drop the car to rest on the stand, then shove another stand next to the jack just in case. If I needed to get under with the wheels off I'd probably slap a couple more axle stands under anything metal
Jacking up the front's much easier and secure. Just one jack to list the sill then another jack under the subframe, then axle stands on the sills
- Site Admin & Mad Biker!
I usually put them under the sill with a block of wood to spread the load and save any damage; also check the jacking points in this picture:
I really don't like using the bottoms of the rear springs for jacking. Firstly they move, and secondly they BEND when any weight's on them...
I totally agree, it's just that I happened to spot it on the diagram.mjb wrote:I really don't like using the bottoms of the rear springs for jacking. Firstly they move, and secondly they BEND when any weight's on them...
I thought bending when there's weight on them was the reason for a spring's existence, or do you mean the bottom arm? Teamster's diagram seems to say this is the approved place for a jack though
I have two sets of stands, one set have the tops squashed flat from sticking them under the front subframe, I'm wondering if I could/should make up a bracket for the tops that actually fits the jacking points...
That'd take all the fun out of it, Steve.steve_earwig wrote:I'm wondering if I could/should make up a bracket for the tops that actually fits the jacking points...
I mean the bottom arm. Where it grabs the bottom of the spring is pretty weak and can't sustain the weight of the whole rear of the car on the area my jack exerts itsteve_earwig wrote:I thought bending when there's weight on them was the reason for a spring's existence, or do you mean the bottom arm?
Approved by Autodata, not Peugeot. I'm pretty sure PSA don't even approve jacking on the subframe (which is fair given it can bend if you don't use wood to spread the load with a V6 up top... )Teamster's diagram seems to say this is the approved place for a jack though
