OK peabodies, can anyone assist with the following:
After a job that should have taken a couple of hours has turned into something that has so far taken over 24 (don't ask) I could do with knowing one of the following if you can help at all. (This applies to the passenger side BTW)
1) The length of the solid bit of pipe work that runs from the rubber to the wheel cylinder and what threads are at each end so I could get a braided version made up?
2) Part number for stealershit replacement of said minute pipe work
3) A.N.Other replacement supplier, I have tried EuroCarParts and Brakes International so far
Thanks people. I would look to make a pipe myself but lack of tools means I can't at the moment
Rear brake line
