Changed the ABS pump yesterday
djp30djp
2.2 16v
Post by djp30djp »
After suffering a string of ABS problems, including split rotors & a broken sensor wire & the pump motor still running with the key removed, & as I was still getting fault messages, I decided to bite the bullet and change the pump unit .
I was dreading it as I have no experience with ABS systems & have heard a lot of horror stories, but it was very easy and now works as it should.
Re: Changed the ABS pump yesterday
Job well done! Glad it went without a hitch! 8)
