Overhauled the rear brakes.
D4B
Re: Overhauled the rear brakes.
Post by D4B »
NSR rear slider freed off, but no way would that have been possible with the caliper ON the car....
Big Vice was needed !
Pleased to report that my 20 year old Gunsons Easy Bleed worked a treat :shock: 8) 8)
Thanks for all the help & advice on here.
Steve
My other Peugeot was a D4B
gumby6371
Post by gumby6371 »
I'll be doing my handbrake cables at the weekend and my backplates are a bit ropey so I was wondering how you did yours DDD?
On the car or off?
If you want to remove the backplates you need to remove the hub/bearing first, so unless your hubs are shot I would try to fix them in situ.... 8)
gumby6371
Post by gumby6371 »
I suspected as much, clean up and paint on the car it is then!
Just had a look on Halfords web site for some caliper paint - red, blue or yellow - WTF is wrong with black? we're not all 17 years old
I got my Kawasaki Green from eBay, but there are many colours available in both brush on or air-arsehole.
Here is the link; http://www.ebay.co.uk/itm/270908604320? ... EBIDX%3AIT
piglet
Post by piglet »
Is this oneupmanship for bits of the car that can't be seen anyway?
If I ever change my backing plates I'm going for C/F effect hydrographic printing
http://www.diamondalloys.co.uk/news/hyd ... or-wheels/
Beat that :cheesy:
gumby6371
Post by gumby6371 »
Now there's an idea! swanky carbon fibre wrap would dazzle the MoT inspector so much he wouldn't notice anything :lol:
On the other hand when I checked service box and found replacement back plates require a small mortgage I thought some wire brushing and a £10 pot of paint was the way to go.
dirtydirtydiesel
Post by dirtydirtydiesel »
gumby6371 wrote:I'll be doing my handbrake cables at the weekend and my backplates are a bit ropey so I was wondering how you did yours DDD?
On the car or off?
gumby,
Sorry for the late reply I had computer probs :roll: , anyhow as ginger said clean up as best you can & paint in situ.
If it help's mine were a mess, I wire brushed them with the electric dill & used Dinatroll rust treatment RC800 then fibre glass to repair the holes & trusty black smoothrite for the finishing coat :cheesy: .
ps I have used smoothrite on calipers with great success & no problems, so you could try some of that in black :wink: .
All the best bud DDD.
dirtydirtydiesel wrote:fibre glass
Umm, don't brakes tend to get a little warm? :(
gumby6371
Post by gumby6371 »
New handbrake cable purchased, dug through shed and found brush attachments for my drill just need the paint now.
My backplates only have surface rust as far as I can tell so I won't need any filler, just brush, treat the rust and paint.
The calipers will probably just get a wire brush as it's not the looks I'm bothered about just the corrosion.
dirtydirtydiesel
Bump :cheesy: !
