So I purchased some 40mm Cobra lowering springs and have fitted the rear, already it looks so much better as it’s slightly more level!
I’m not looking forward to doing the front as from what I gather it’s a bit of a ball ache!
Sits too high at the back?
- 1.8 8v
Re: Sits too high at the back?
1998 Diablo red 406 V6 manual estate - Sold
1998 Dark green? 406 V6 auto estate
1981 DeLorean
1966 Reliant Scimitar coupe (in bits)
1981 DeLorean
It's do-able with the right tools but still a bit of a risk, might be better to find a local garage wiht a proper spring compressor jig thing and take your struts there.
Definitely a job for someone with the right tools, or that spring could do you an injury...
It's also a good time to replace the strut top bearings seeing as the struts will be removed....
I lowered the back of my 406 by simply filling it with 6 concrete planters..
Good luck with it, the 406 does look better with a little lowering in my eye.
Until you fit the 40mm lower front springs then back to square one
You just need some good spring compressors (don't try without them)
You can cut your old good one (like your broken one) before taking off the strut top & yes 100% fit new strut top
bearings while your in there.
2006 BMW e61 535d m-sport
run's for cover
