handbrake shoes
handbrake shoes
just a quick question:
are handbrake shoes inside the discs all the same ? on the 406
seen some on ebay for £9
took a disc off the rear and a piece of friction material fell out , only leaving half of the fiction material
I suppose they have not been renewed for over the time I have had it nearly 10 yrs 125k !
Re: handbrake shoes
Yep, all the shoes inside disks are the same, 9 quid sounds a bit too cheap mind...
Re: handbrake shoes
Cheers Steve
Re: handbrake shoes
Found another set at £ 10,81 from https://www.autodoc.co.uk/ridex/8237530 .
Current "fleet":
2003 406 Estate 2.0HDi 110 - 7 seater - just hit 690.000 kms
2001 Citroen Saxo 1.6i 8v 100
Previously owned:
2000 406 Sedan 2.0 HDi 90
Previously owned:
Re: handbrake shoes
ordered some mintex ones , £18 fast free postage off ebay . same price as autodoc ones with postage
Quick question, can you paint the backplates with cheap house paint ? or do I need High Temp Paint ?
Re: handbrake shoes
Aynthing's better than the standard bugger all. They're rears so they shouldn't get that hot.
Re: handbrake shoes
They should be plastic coated.....
Probably not anymore though - I just painted mine with Hammerite before the ball ache of reassembling the shoes and springs...
Re: handbrake shoes
Bitumastic paint is probably better from a rust prevention point of view. You need the softest lings you can get for the very inefficient handbrakes on the 406 but I don't know who makes them, some research would be necessary.
Re: handbrake shoes
Update:
found some rustoleum in back of the garage for the backplates, looks good
done one side, but need to fix the old backplate pin problem a s bottom one too sloose ,might pop out and make a mess !!
seen threads on here to use bolts. I could do this but just a thought, has anybody tried to to reverse the pin and fit an old type concave locking washer that they used in the old days !!
Basic Question: need to get brake pipe out of the caliper as I need to renew all the seals ! , the brake pipe is just twisting when I turn the nut , Is there a trick to getting the brakepipe to free from the nut you turn ( don't no what you call it ? lol) I do not have a blow torch . I have used WD40 , tapped the pipe inwards !!
If I cannot release it I will have let the garage do it as I do not have brake pipe making flareing tool
Story about calipers needing new seals !!!!
Fitted new calipers about 2yrs ago from germany ( should have known they were to good to be true, brand new in the box £80 for the pair )
when doing this job I noticed the seals were all totally nakt, all split and cracked !
Re: handbrake shoes
Take the caliper off and unscrew it from the pipe. Refitting is reverse.
Re: handbrake shoes
Cheers peter, yes had a look at youtube vids
got the job done, backplates a bit ripe , so painted them with rustoleum.
renewed all the seals in the calipers job done !
Re: handbrake shoes
Just a heads up for anyone doing the rear handbrake Shoes
My vehicle is a 2003 406 HDI 90 Estate
In answer to the original question, Yes there is more than one size ! I read this thread and ordered a set of rear handbrake shoes it did not matter from where I purchased them from as the answer was !Yes they are all the same"
Well I have spent 3 hours in the Pi**ing rain trying to work out why my new handbrake shoes would not release when handbrake was released, it turns out that the shoes are approximately 10-12mm longer that the worn out shoes I removed so they space off the lever mechanism.
My only worry now is how I find the smaller shoes that are fitted to my car as they are supposedly all the same.
I am now off to annoyingly throw the ones I have just purchased in the bin
Re: handbrake shoes
Can anyone give me a part number for rear Handbrake shoes that will fit My 2003 Peugeot 406 HDI 90 Estate car, as previous post the ones I purchased are a different size to the ones on the car, I have taken photographs of the old and new shoes but cant seem to upload them to show everyone how do I upload Photo's ?
Any help greatly appreciated MOT on the 7th October and no handbrake
Re: handbrake shoes
Look it up on: https://catalogs.ssg.asia/peugeot/?lang=en
using your VIN, that should get you the Peugeot part no.
Re: handbrake shoes
Hi Doggy,
Thank you, I will try that and see what result I get, did not know that look up was possible
Thanks Again
Thanks Again
