Quality OEM parts for 406.
MyPug
Post by MyPug »
Fed up replacing ball-joints and bushings.
Is there any quality parts you can recommend that does not need replacement every 12 months or so.
Febi vs Moog vs Lemförder vs Mapco vs …
I know Lemförder is very good for BMW anything rubber. But is it any good for Peugeot 406?
Parts I am after: Tie rod 3817 40, 3817 39 and maybe 3812 C4.
2003 HDi, 90HP (DW10TD), saloon D9, 5 speed manual (ML5C), silver met (EZR).
dirtydirtydiesel
Re: Quality OEM parts for 406.
Post by dirtydirtydiesel »
I replaced my estate drop links with lemforder one's & there still going strong 3 1/2 years, 40k later :)
But I have just bought some Meyle HD ones for my coupe & these come with a four year warranty :D
So hopefully they should last even longer :cheesy: .
Hope this helps DDD.
grasmere59
Post by grasmere59 »
I changed my drop links 3 years ago and used Lemforder and still all good.
2012 "62" Yamaha XT1200
1974 "M" Honda CB500/4
1994 "M" Kawasaki Zephyr 1100
1998 "S" Honda XRV 750
PeterN
Post by PeterN »
If buying on ebay look for the droplinks/tie rods that have an allen key hole in the end for holding the centre still, look carefully at the pictures and check the quality of the rubber boots - they are what usually fail. Since I have been buying that type I haven't had a problem.
Also those without the allen key facility are impossible to do up really tight and if there is any movement in them they will rattle, just done one on a Coupe, sounded as though it was clapped out but was actually only loose - the rubbers had gone though.
