Unfortunately there is still an annoying squeaky noise (technical term) over the lumps and bumps.
I noticed the top spring cup (no idea of the correct name) had quite a lot of surface rust when I was doing the mount so I cleaned up the face the bearing sat in but didn't wire brush the spring side as it was on the spring pretty firmly and I was a bit twitchy about persuading it while the spring compressors were on.
Is that likely to cause a squeak? I'm (fairly) confident the spring is flush against the stops in the top and bottom cups.
My other thought was ARB bushes but it only seems to come from the top of the drivers side and I assume you'd hear a squeak from both sides and lower down?
