Hi all,
I'm looking to buy one of those extendable wheel brace thingies for my 96 406 (bent the standard brace trying to get a wheel off last year). Can someone tell me what size socket the wheel nuts need?
Thanks.
406 wheel brace size
Re: 406 wheel brace size
19mm on mine.
I use an extendable wheel brace. Came with 2 detachable double ended sockets.
Gives , IIRC.., 17, 19, 21, 23mm.
2006 Toyota Yaris 1.0 T3
1993 Mazda MX5 Mk1 1.6
Mine are 17mm and my spares are 19mm. I too have an extendable tool, which has a 17/19mm double socket. I've also used it for undoing pulleys and hub nuts.......
I have a combination of 17mm with 19mm D8 lock nuts
406 Coupe S HDi
PP2000 clone interface
406 Coupe S HDi
I got an extendable brace with 17/19 double ended socket from Tesco a few years back for about £5 and have used it time and time again on many cars, just fits in a 406 wheel well.
As an additional observation if you ever bother with a torque wrench to check them you'll be amazed how little effort is needed for the manufacturers recommended 90 nm setting!
2003 2.2 HDI SE
2003 2.2 HDI SE
