abs pre load pump
neilhdi
abs pre load pump
Post by neilhdi »
can anyone shine any light on what the abs preload pump does on my car please im having some trouble with the brakes ive got a pedal that take 3 pumps to make it work as it should,the problem came from no where as i left a motorway junction needless to say the big stone brakes at the side off the road helped me stop!! oh yes it a 53 plate 110hdi exec estate with esp ive blead brake no change was going to change my master cylinder for a secondhand one but its a 3 port unit so rare as hens teeth secondhand then i notticed the strange part that turns out to be the pre load pump, does anyone know what it does??? :x
2004 406 110hdi executive estate monaco blue coupe wheels egr blank F&^ked brakes
2004 renault scenic 1.9 dci 120 remaped decated egr blank
1998 citroen zx 1.9 td sx 3 door gti6 running gear bosch'ed fmic t25 turbo plenty off smoke and poke
Re: abs pre load pump
Hi @welcome to the forum,
Have you checked the Vacume pipe to Master cylinder?.
neilhdi
Post by neilhdi »
yes checked everything servo work perfect no vacume leaks and will brake as before once ive pump pedal 3 times!!!!!!!!!
has it got one of these fitted?
http://www.ebay.co.uk/itm/PEUGEOT-406-1 ... 45f971ebe5
ibelieve some do some don't,.
but if it does maybe its worth seeing if its sticky?
link from another forum - http://www.peugeotcentral.co.uk/ftopic-4810.html
see post on there from Mr canyon dust,
neilhdi
Post by neilhdi »
lozz wrote:has it got one of these fitted?
no its not got a load valve i can categorically say its not the rear brakes as i have fitted a whole new rear axle assembly compleat with calipers, and new front discs and pads at witch point ive inspected sliders ect
i have the same problem still and im getting poorer :evil:
neilhdi
Post by neilhdi »
does any one know what the pre load pump does and if it failure causes this problem?
markw
Post by markw »
Does your car have the ESP option? (Electronic Stability Program)
I thought the pump is for that system, in as much as if your car gets into a skid, the ESP system will operate the brakes on one or more corners of the car to attempt to correct your trajectory!
This pump is what pressures up the hydraulics to make things happen...... :!:
