My 98 2.1TD Executive
Bailes1992
Re: My 98 2.1TD Executive
Post by Bailes1992 »
Gary406 wrote:
Bailes1992 wrote:If your ever planning on getting rid of this car, can I please have first refusal? :D
south wales to northumbeland is sum miles :shock:
If car was in working order I'd have found the money somewhere and driven it back.
I'm tempted to offer him for it in the condition it's in and stick my 1.9TD in it, BUT got no room to do it and can't get it back from Northumbeland unless I get the train up and from the AA "My timing belts just snapped" :lol:
Tow it back, (preferably with the 406).
i think its being broken already.
HimBigChief
Post by HimBigChief »
Not yet, still stuck across the garage, but hoping to rectify that shortly.
Tempted to fix, whack a Bosch pump on it and run it on veg oil at 48p per litre. Should cut my running bills dramatically, but will need to decide once I've seen how much damage there is to the engine.
Image Image
how hard can it be at the worst its a new engine
Bailes1992
Could pick up an XUD9 for £150 with a bosch pump. Just drop it in and give it a good tune?
ok ive been hearing about this for a long time, whats the difference in the lucas and bosch pump. Are some cars fitted with each type, does this apply to the xud. Is the bosch better.
Bosch = pump
Lucas = trouble / allergic to veg oil
FarmerPug wrote:ok ive been hearing about this for a long time, whats the difference in the lucas and bosch pump. Are some cars fitted with each type, does this apply to the xud. Is the bosch better.
Bosch - found in the 1.9
Lucas - found in the 2.1
sum1 said sum 1.9s have Lucas fitted but ive never seen or heard of that before :?
HimBigChief
Would prefer to keep it 2.1 really, but put the Bosch pump on and then up the fuelling and boost and see what sort of power I can get. Should be able to get 150bhp easily I would have thought. Run it on veg oil too for maximum cheapness and mainly to stick one's finger up at Mr Chancellor and his bloody taxes. :cheesy:
I didn't hear any sort of bang or noises when the belt went, so fingers crossed it hasn't caused too much damage. Also, I've rearranged my finances and can afford to keep the 406 and the new car. I should also be able to afford to actually slowly fix the 406 and do the Bosch pump swap before getting it back on the road.
Still haven't decided what to do yet, and once I get the 306 on the road, the 406 back here and time to assess the damage I should be able to make an informed decision.
Image Image
if you dont need the cash from breaking it i would keep it mate
it will give you something to work on from time to time,
HimBigChief
Already got my 309 for that! :roll: It'd just be cheap to run if I could veg oil it, and be worth it for the work run.
Image Image
HimBigChief wrote:keep the 406 and the new car
What did you get / are you getting?
HimBigChief
Got a moonstone blue 306 HDi estate as a temporary runabout. Should be cheap enough to run about in for the time being. I've just checked the real MPG on the missus 306 HDi estate (we've now got a red and blue one) and it's returning just shy of 50mpg, which when you consider we live in the middle of the Pennine's is pretty good. Anyway, I've just had the new one delivered about 2 hours ago. The same guy should be able to collect the 406 at the weekend as long as we can get to it, i.e. the compounds not locked. He was telling me about the Lamborghini's and Ferrari's he's had on the trailer, so the ride height on the 406 should cause him no problem.
Need to get the drivers side hub off and the bearing swapped out on the new one ASAP, and there's a few other little bits to tidy up, and then it should be pretty much spot on. Will run around in it for a while, and if it's better than the missus car, she'll keep the new one, we'll sell hers and either fix the 406 and run it on veg oil, or sell both and get something a bit more practical for round here.
Image Image
sounds like a good plan.
