Apprentice electrician, my Fathers an also a Spark by trade (Although is an Engineer now)... But we have our stashes of crimps
I can't say I've ever trimmed a spade connector down
I would assume it would effect the currect carrying capacity of the crimp. But you should be fine with the airbags because it's only every going to carry current for a very short amount of time anyway.
Bailes1992 wrote:I can't say I've ever trimmed a spade connector down
Cool........ It's the seat belt pre-tens
Just wouldn't fit neatly together and didn't want to leave metal exposed in the middle
'Miss Pug' Peugeot 406 2.0 16v Petrol 'Family' Estate.
6th December 2011 - November 2014
24th January 2017 - Current (I bought her back!)
Ohhhh I thought you meant they are too wide!
Spade connectors don't go together completley. I usually use a bit of headshrink over them.
If you didn't want to tape them up or head shrink them then you would probably be better off with bullet connectors!
Bailes1992 wrote:Ohhhh I thought you meant they are too wide!
I couldn't find any insulated bullet connectors
Yeah - they just wouldn't tuck into each other nicely.... As I put in the blog though I would of ideally liked to use heat shrink but the problem is, more set up costs of having a heat gun = I really can't afford that with the house move coming up within a month or so's time. Thanks for your advice.
Sonia406 wrote:As an ex-smoker I think I'd have to really hunt for a lighter anyway
Your car has a cigarette lighter built in - no idea if it'd be any good for this, but I bet it gets pretty damned hot!
